problem in output
problem in output
problem in output
i'm studying the behavior in fissuration of a stainless steel (304L).
in input, i impose a dispacement( by steps)with an amplitude of 0.0175mm (that corresponds to a deformation of 0.14%).
The problem is that i find a difference with the value of displacement in output ( i find 0.00175mm and a deformation of 0.014%).
Can any one help me?
RE: problem in output
well... it seems you definetely have to look for a "10" anywhere..
check out units and the amplitude.
quite sure you knew it..
good luck! = )
