horse stable design loading
I am involved in converting a second floor space for use as a horse stable in Manhattan for storing horses used in the carriage rides around the park. The building code does not address this use in it's allowable design live loads. My inclination is to use 100PSF for yards and terraces but would appreciate any input on this. The carriages and hay will all be stored on the first floor.
Also,I need to specify an applied waterproofing over a sloped topping slab that will withstand horse urine. Anyone specify something for vet/kennel project that they were happy with?
RE: horse stable design loading
I have no direct experience in this area, but a google search on "precast planks for cattle sheds" yields a lot of fascinating info. I spent a glorious hour wandering through it.
good luck
First of all, I would guess that the design floor loading for a parking garage would be applicable since you are parking the horse drawn vehicles there (along with the acutal "horsepower"). Most codes call out something on the order of 50 - 75 psf for that. My personal opinion is that 100 psf might be a little high over the whole area. I would would layout the storage areas and calculate what the expected hay load is (what the hay! <G>). I would think that 100 - 125 psf in the storage areas would be adequate. One thing else to think about is in the event of a fire, the fire protection sprinkler system would wet down any stored hay, which would make it pretty heavy in its wet condition.
For the floor covering, I would think a 1/8" to 1/4" epoxy coating would be just fine, similar to what is used in a food prepartion area. They are waterproof, chemical and acid resistant, so cleaning would be easy and sanitary.
Best of luck!
1. The bond strength of the epxoy is higher than the tensile strength of the concrete.
2. The suitability of the lightweight concrete for use in your "stable" will depend on its strength and unit weight. It it is too low it will not stand up to the traffic.
I really believe your best bet is standard weight concrete with an epoxy topping. Call some epoxy topping installers and get information on the suitablilty and cost.
