GD&T flatness tolerance
Can anyone tell me how will you designate flatness tolerance for multiple surfaces on the same datum plane as per ASME Y14.5 std.
PS: I have several surface projections on the same plane but I need to specify a flatness tolerance for that entire surfaces using a single tolerance value. For ex: Profile tolerance symbol & .010 value for X number of surfaces.
RE: GD&T flatness tolerance
However, if using -1994 standard I'd take a look at the section on coplanarity 6.5.6 & associated figures 6-20 & 6-21. If it really is being used as a datum plane look at 4.5.7 as well & figure 4-20.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
