HDPE PIPE AS FORCEMAIN
I have never used HDPE pipe as a sanitary sewer force main. Has anyone used HDPE pipe as a force main before? Can HDPE pipe be jacked and bored? What type of testing is required for HDPE? Has anyone experienced any failure in the use of HDPE?
RE: HDPE PIPE AS FORCEMAIN
Project was uneventful.
http://www.performancepipe.com/en-us/ww/Pages/default.aspx
HDPE is a very old fashioned term but still used in industry. High density polyethylene is rarely made as it does not have the improved properties of medium density PE. Medium density PE is commonly just known as PE. It does comes in a number of grades primarily PE 80B and PE100. It is the latter that is in common usage.
Back to you questions:
Yes it is commonly used in direction drilling for sewer forced mains.
PE is hydrostaticaly tested slightly differently to legacy materials like steel and ductile iron. The phenomenum of creep has to be taken into account. The relevant national standards or AWWA references will cover this aspect.
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. Kinghttp://waterhammer.hopout.com.au/
http://www.trenchlessonline.com/pdfs/2010_Pipe_Materials_Guide.pdf
Here is a link to a design guide for PE pipe:
http://plasticpipe.org/publications/pe_handbook.html
Frequently Asked Questions HDPE Pipe for Water:
http://plasticpipe.org/pdf/tn-27-faq-hdpe-water-transmission.pdf
