Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Compliments on a fantastic web site. I have learned so much from my threads and even if sometimes I cannot solve the problem, it gives me the reassurance that I am not the only one putting up with it!..."
Geography
Planet set gear addendum modifications and clearance.
ukjay1 (Mechanical)
4 Jun 12 10:34
Hi Guys
I have an planetary set I'm designing, where I had to do addendum modification to sun gear none to planet gear, and this increases the center line distance.
Now is the general rule of thumb to make the same negative addendum modification to ring gear? To have proper clearance? Or do I move the ring gear cut pitch dia out further (i.e..amount of center distance change)?
As it looks to me the 1st option in laying it out I'm getting intereferance with planet and ring gear.
Please comment with suggestions.
tbuelna (Aerospace)
4 Jun 12 21:38
ukjay1,
With simple epicyclics, there are lots of tweaks and compromises to balance the requirements of tooth bending strength, relative contact sliding, etc. You can adjust the ring gear PD, the planet gear PD, the planet gear PCD, or any combination thereof. Just remember to fully evaluate the effects of these tweaks with regards to issues like contact sliding. Also be sure to apply adequate tip relief to your gear teeth to ensure smooth meshing.
Hope that helps.
Terry
dinjin (Mechanical)
11 Jun 12 23:06
Your method works and probably is a good method rather than changing the center distance depending on how much you modified your sun gear. You might want to consider stubbing the ring gear a bit too.
Close Box
Join Eng-Tips® Today!
Join Us             Close
