Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...What a great service! This is the best site I've ever seen!!! It totally restores my faith in humanity when people take time out to help other people..."
Geography
chemhasan (Petroleum)
4 Jun 12 9:17
In a power plant, the cover of insulation material for pipes and tanks is aluminum. Soot caused by fuel oil burning is clinging on to the surface of aluminum. What is the best solvent to remove the soot? (The best in view of economic and efficiency)
bimr (Civil/Environmental)
4 Jun 12 16:40
A chemical sponge available from a cleaning supply company or some other non-water-based cleaner may be used to clean soot from surfaces.
http://www.amazon.com/Soot-Eraser-Sponge-Case-12/dp/B0041SIB5I
Paint thinner or rubbing alcohol may work, but use with caution because of toxicity and fumes. Wear rubber gloves, and use ventilation while working.
It may be easier to just replace the insulation covers or paint the covers. After several years, the aluminum is probably already oxidized on the surface.
bastianguy (Automotive)
10 Jul 12 20:19
If it's on aluminum it shouldn't be too difficult to remove it. There are many oil removers out there.
Close Box
Join Eng-Tips® Today!
Join Us             Close
