fan pressure testing
hi guys
i need to test the pressure delivery of a fan
I have an electronic type pitot instrument
my instrument only has straight tubes
is it required the tubes face into the airstream or could it be perpendicular to the flow i.e straight throuh the duct?
RE: fan pressure testing
We can't be sure what "electronic type pitot instrument with only straight tubes" is.
Also, are you testing static pressure only? Or do you actually need to confirm flow, which requires velocity pressure?
Good on ya,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
