Generating Balloons via macro and Ballon text source
Hello all!
Is there a way to change Ballon text source via macro?
To clarify: When you go Tools/Options/Mechanical Design/Drafting and than on "Annotation and Dress-Ups" tab you have combobox to choose whether balloons will show Numbering, Part Number or Instance Name. I have been struggling for days and digging through Automation help file and VBA object browser to find an answer but couldn't find anything on the matter.
Also, is there a way to generate balloons via macro without using start command? I am asking this because the only way i know how to do this is start command, since i haven't found anything in help file on the matter also.
I also tried to dump parameter values for "Annotation and Dress-Ups" tab but file generated is empty.
And in the end, is there a way to set up Balloon text source to some other parameter besides Numbering, Part Number and Instance Name.
I am asking this cos i am trying to somehow overcome first level numbering problem. In this topic http://www.eng-tips.com/viewthread.cfm?qid=133081 shasbarg said that in their company they numbered subassemblies through instance description, which i understand how, but the thing i don't get is how to populate balloons with these values.
Thank you in advance
RE: Generating Balloons via macro and Ballon text source
Sorry i forgot about something else.
Since i could't find anything about this too...
Is there a way to loop through all balloons in view. Meaning, are balloons recognized as balloon object or some other object and what collection they belong to.
This is something which I was also interested at one moment and at that time I found an answer on net (can't remember where and who posted this).
Balloons are presented in Automation as DrawingText objects, because basically balloon is a text with round frame, leader and positional link to target object (all of this can be set up programmatically).
In order to create "real" balloon programmaticlly your easiest and most likely only option is to copy-paste one that is already in a drawing and modify it's properties according to your needs. This way you depend on having at least one balloon in your drawing. To be sure that it is present you can:
a) easy way: ask user to create one before launching your macro.
b) hard way: using CATIA.StartCommand method (as you know), launch balloon creation command, enter any text in
opened dialog window (with WinAPI) and then send a mouse click to drawing editor window to indicate position of balloon (WinAPI again).
Either way you should have balloon in your document that you are able to operate with.
To loop thru all your balloons, I believe you can also search for name = Balloon and create a Selection....
Fernando
https://picasaweb.google.com/102257836106335725208
Ferdo, these infos you provided help a lot. Thanks for reply. In next few days i will play with this and hopefully come up with something.
Few things though...
This copy/paste method you proposed seems like a good idea, but what i don't know is how to programmicaly modify position of Balloon leader anchor point to point to specific object.
To clarify: you need to loop through all components in a view/s that are generated from 3D model and find its position in screen in order to indicate X,Y position of mouse click. Is this even possible? If not i don't actually see much sense in doing this because you would have to manually reposition all leaders, and this is something Catia provides anyway.
If this is not possible, then is there a way to know to what object are Catia automatically generated balloons pointing to? This would help a lot.
what you proposed under a) could also be done via CATIA.StartCommand so you don't have to ask user to create one.
that's all for now. thanks for reply again
I don't know if this will help but create a drawing with one balloon and test the code bellow, maybe will give you new ideas (it will move the leader from one point to another).
CODE --> CATScript
Option Explicit Sub CATMain() ' Access through document's structure Dim DrwDoc As DrawingDocument Set DrwDoc = CATIA.ActiveDocument Dim colSheets As DrawingSheets Set colSheets = DrwDoc.Sheets Dim ActSheet As DrawingSheet Set ActSheet = colSheets.ActiveSheet Dim colViews As DrawingViews Set colViews = ActSheet.Views Dim ActView As DrawingView Set ActView = colViews.ActiveView ' get first text from active view Dim txtFirstText As DrawingText Set txtFirstText = ActView.Texts.Item(1) 'just first one ' get leaders collection for first text Dim colLeaders As DrawingLeaders Set colLeaders = txtFirstText.Leaders Dim ldrCurLeader As DrawingLeader Dim objCurLeader As AnyObject Dim ArrLeaderPoints() As Variant Dim dblAnchorX As Double Dim dblAnchorY As Double Dim dblTextX As Double Dim dblTextY As Double Dim iPointsCount As Integer For Each ldrCurLeader In colLeaders ' get coordinates of anchor point Call ldrCurLeader.GetPoint(1, dblAnchorX, dblAnchorY) MsgBox "Leader point coordinates are: " & dblAnchorX & " " & dblAnchorY '~ Call ldrCurLeader.RemovePoint(1) ''uncomment if you want to remove the leader dblTextX = dblAnchorX + 100 dblTextY = dblAnchorY + 100 MsgBox "New leader point coordinates are: " & dblTextX & " " & dblTextY Call ldrCurLeader.ModifyPoint(1, dblTextX, dblTextY) Next ' ldrCurLeader End Sub
Fernando
mad
CODE --> CATScript
Option Explicit Sub CATMain() ' Access through document's structure Dim DrwDoc As DrawingDocument Set DrwDoc = CATIA.ActiveDocument Dim colSheets As DrawingSheets Set colSheets = DrwDoc.Sheets Dim ActSheet As DrawingSheet Set ActSheet = colSheets.ActiveSheet Dim colViews As DrawingViews Set colViews = ActSheet.Views Dim ActView As DrawingView Set ActView = colViews.ActiveView ' get first text from active view Dim txtFirstText As DrawingText Set txtFirstText = ActView.Texts.Item(1) 'just first one, for second put 2 a.s.o. ' get leaders collection for first text Dim colLeaders As DrawingLeaders Set colLeaders = txtFirstText.Leaders ' "straighten up" each leader Dim ldrCurLeader As DrawingLeader Dim objCurLeader As AnyObject Dim ArrLeaderPoints() As Variant Dim dblAnchorX As Double Dim dblAnchorY As Double Dim dblTextX As Double Dim dblTextY As Double Dim iPointsCount As Integer For Each ldrCurLeader In colLeaders ' get coordinates of anchor point Call ldrCurLeader.GetPoint(1, dblAnchorX, dblAnchorY) MsgBox "Leader point coordinates are: " & dblAnchorX & " " & dblAnchorY '~ Call ldrCurLeader.RemovePoint(1) ''uncomment if you want to remove the leader dblTextX = dblAnchorX + 100 dblTextY = dblAnchorY + 100 MsgBox "New leader point coordinates are: " & dblTextX & " " & dblTextY Call ldrCurLeader.ModifyPoint(1, dblTextX, dblTextY) Next ' ldrCurLeader End Sub
Fernando
I give up, no way to use "code" and have a nice text format...it was better before last improvement of the forum...
Option Explicit
Sub CATMain()
Next ' ldrCurLeader
End Sub
Fernando
