Gas Turbine Performance Monitoring
What key performance indicators (KPIs) and benchmarking standards are routinely used to monitor the operation and maintenance of gas turbines:
What KPIs are tracked? (MTBF, Availability, fired hours, # start-ups, others)
What condition monitoring tasks are done? (air filter delta pressure, exhaust temperature, heat rate, emissions levels, vibration analysis, lube oil analysis, others)
What types of preventive maintenance tasks are done? (borescope inspections, on-line/off-line water washes, others)
How are best-in-class gas turbines performing and per what criteria?
Thanks for your input.
