Edit sketch from assembly gone?
Using 2012 SP3.0 here, and I just noticed that I can not click a part in an assembly, and edit the sketch of whichever feature is selected. I can edit the part, or add a new sketch, but not edit the existing one. If I right click the feature in the tree, then I can edit the sketch, but that requires knowing exactly which part and which feature it is I want to edit. I used to use this all the time. I'll probably submit it to SolidWorks, but just wanted to see if anyone else has any input on it first.
Matt
Matt
RE: Edit sketch from assembly gone?
Matt
SW 2012 Pro SP3.0
HP Z210, Win7 Pro x64
Core i7-2600, 16GB RAM
Quadro 2000
Even more interesting, if I create a new assembly, and put all the assemblies I tried in that one, then the ones that have the option still have it, and the ones that don't have the option still don't.
Matt
SW 2012 Pro SP3.0
Quadro 2000
Matt
SW 2012 Pro SP3.0
Quadro 2000
What do you think... bug?
