using the same sketch in diferent functions
Is there any way? The functions I want to use are cosmetic / groove. I have to repeat the same sketch in some parts.
RE: using the same sketch in diferent functions
It will come in and you canscale it and rotate it. You will have to redo dimmensions and constrants.
The other way to do it is copy the features you want to use or create the skecth in a dataum curve and reference that curve in the different features. This would make the two features update together when the curve is changed.
ProEpro
www.whitelightdesign.com
Give proper names to all prompt so that in later stage you can place that UDF with proper reference.
Cheer..
Yogesh
