Catia v5.20 Need help with a Macro for copying all Annotations and captures into a folder
I have a macro right now that copies "part parameters and mass properties" into a text file. Where I work we call them "Spec Tree Notes".
I really would like to be able to make screen shots of all the views labeled Primary datum’s, GD&T and so on. And put them into a folder with the text file that contains the "Spec Tree Notes".
I have NO VB programming experience at all.
Can anyone send me in the right direction either with a macro or a good lesson on learning this code?
John B
RE: Catia v5.20 Need help with a Macro for copying all Annotations and captures into a folder
I have seen this as a third party application you could pick up from Rand or Ascendbridge. Here is a link to a macro for export of an annotation set.
Link
Derek
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
Thank you Derek
John B
