What causes throttle body fouling?
In looking at the induction system of modern fuel injected engines, it's not apparent where the contaminants come from to foul the throttle body. On my vehicle the only additional connection between the air filter and throttle body is the air supply for the PCV system (which should be flowing away from the intake). Is it caused by unburnt fuel vapors flowing backward after engine shutdown? If so, would direct injection engines be less susceptible to fouling?
RE: What causes throttle body fouling?
Tmoose♦
The PCV system takes air at atmospheric pressure (from the intake air duct upstream of the throttle body in my car) passes it through the crankcase, and into the intake manifold downstream of the throttle body. From there it gets burned in the cylinders. So there should not be any flow of "contaminated" air past the throttle body.
""The PCV system takes air at atmospheric pressure (from the intake air duct upstream of the throttle body in my car) passes it through the crankcase, and into the intake manifold downstream of the throttle body. From there it gets burned in the cylinders. So there should not be any flow of "contaminated" air past the throttle body.""
This works fine when an engine is new.
When the rings start to wear, at full throttle the crankcase gasses overwhelm the system.
resulting in excess gas passing back out through the intake duct upstream of the throttle body and into the engine via the throttle body. The PCV valve is supposed to stop this, but they tend to get carbon in them and leak allowing the back flow.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them. Old professor
Also some fine particles make it through the air filter.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Mike Halloran
Pembroke Pines, FL, USA
"Note also that the idle circuit, typically part of the throttle body, contains a small primitive carburetor. Hot soak will cook the fuel trapped there"
I thought the idle circuit was just an air bypass around the throttle body with a small stepper motor-actuated valve to control the flow. Never heard of it having a fuel source.
Pat
for site rules
IAC in/on throttle body has no fuel source.
It does have a gunk source; reversion, fumes from fuel/oil cookoff farther downstream in hot soak, crankcase vent vapor, whatever.
Mike Halloran
Pat
for site rules
On my motorcycle (3 cylinder, 1050 CC, port injected) with no PCV or EGR the throttle valves and intake valves are as shiny clean after 6 years as they were the day it was made. Rather modest cam timing on these, must be little or no reversion.
I would think most automotive engines with variable intake cam timing would also have very little reversion these days.
Most of the replies seem to indicate that the fouling is caused by fuel, EGR, or PCV vapors from the intake manifold, which makes sense to me. That would indicate that most of the "crud" should be on the downstream face of the throttle body butterfly or on the bore of the body just downstream of the butterfly. Has anyone seen this to be the case?
Mike Halloran
Cheers
Greg Locock
This can be a problem for highly boosted/downsized engines that don't spend as much time with low manifold pressures compared to their NA equivalents, if you have a problem with this you need to have a 2nd purge connection to the intake path, up stream of the compressor.
