Ductile Iron pipes to Lugs (made of Ductile iron) standard cooling rate after welding
HI,
I need to know the standard practiced cooling rate for welded joints (Ductile Iron pipes and Lugs) I could find some information that says air cooling is better,However my senior engineer wants to be able to prove it. ie, it has to come from a reliable source. I tried hard but couldn't really come up with a standard. It would be great if any of you guys could help me out with this.
RE: Ductile Iron pipes to Lugs (made of Ductile iron) standard cooling rate after welding
You may find the link helpful.
Field welding and cutting Ductile Iron pipe.
http://www.dipra.org/publications/guidelines.cfm
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
