Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I love this site! It's so nice to know that there are so many people out there who are willing to share their knowledge..."
Geography
mechtr450 (Mechanical)
31 May 12 18:53
If a hydraulic steel tube of diameter 10mm and wall thickness 1.5mm is bent to a radius of 100mm how can I work out the reverse radius of curvature needed to straighten the tube?
I believe the only way to straighten the tube will be to apply a reverse bending moment at each end of the tube. As the tube has yielded and undergone plastic deformation then the only way to straighten this will be to 'overbend' it past straight; otherwise it it will elastically spring back to a slightly less radius of curvature (assuming that it has started to see plastic deformation again).
What I need to do is find away of ascertaining the amount I need to overbend it by. If I work out the strain required to straighten the beam then what needs to deternmined is by how much the strain needs to be exceeded by to achieve a straightened tube.
mfgenggear (Aerospace)
31 May 12 20:03
mechtr450
what are you trying to accomplish?
the tube has stretched & compressed. the outside radii has thinned wall thickness, & the inside is now compressed.
Depending on the material, The tube will need to be annealed or it will crack.
This is to my opinion a trial & error situation.
the tube is probably scrap.
mfgenggear
MiketheEngineer (Structural)
31 May 12 21:36
Agree - unless it is made out of gold or the last piece of pipe on the planet. - scrap it. You will never get right - maybe slightly close
berkshire (Aeronautics)
1 Jun 12 1:32
This is most likely a futile effort. But assuming you HAVE to do it. Anneal the tube first, insert a bending spring into the tube, then start straightening using 4 degrees of springback first. Fine tune this as you get closer to straight, using U blocks, a straight edge and a press for final straightening. Good luck with this.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them. Old professor
TheTick (Mechanical)
1 Jun 12 1:35
Do you really think you can straighten a tube for less than the cost of a new one?
1 Jun 12 3:32
All many thanks for the replies.
This is purely a theoretical exercise so I have made the assumptions that the tube undergoes pure bending and doesn't not have any irregularities along the wall thickness where a plastic hinge may form.
I do agree though that if this was a real life situation then the tube would be scrap. I'm just looking for some pointers as to where to start with the theoretical workings. If its easier to invisage the dimensions of the tube can be whatever they want.
HDS (Mechanical)
1 Jun 12 7:43
Theoretically I would grab each end and stretch the tube until the entire thing yielded. In reality it can not be done (unless you melt it and recast it :).
1 Jun 12 8:40
HDS, that would be the equivalent of applying an axial force which in theory would mean an infinite amount of force needed to ensure that it became completely straight? By applying a moment at each end of the tube then surely it can be worked out by how much it needs to be overbent by?
vpl (Nuclear)
4 Jun 12 10:37
When you say this is "purely a theoretical exercise" -- is this a polite way of saying this is a classroom assignment?
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
4 Jun 12 19:20
vpl - No it isn't.
Close Box
Join Eng-Tips® Today!
Join Us             Close
