Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...it was ingeniously designed and all those clicks were for my own good... and that was even before I got my speedy and useful answer to my tekkie question that I eventually posted..."
Geography
Explanation for change in magnitude after random vib test
Astorite (Mechanical)
31 May 12 17:34
As a small company and being new to vibration testing, we are having difficulty in explaining to our customer the reason for a change in magnitude on a post random low level Sine test. The background is that we complete a functional test on the equipment, Pre LLS test (0.5g @ 20-2kHz), Random vib, post LLS test and then a post functional test. Both X & Y axes were fine with correlation on the pre/post vib plots and the post functional test was fine for all 3 axes. However, in the Z axis, the magnitude at resonance reduced by approx 50%. There was a minimal change (~2%) in resonance for the pre and post plots. The unit wasn't altered nor moved during the z axis testing.
The customer specification allows a deviation of 10% on frequency and 40% on magnitude. As we are outside this, it's a test failure.
As far as an explanation, the reduction in magnitude suggests some settling of the unit in this axis provided additional damping.
Any other thoughts /experiences?
GregLocock (Automotive)
31 May 12 17:55
I suggest you post the plots for all 3 axes pre and post test
Cheers
Greg Locock
1 Jun 12 4:47
As requested, I've attached the plots for the Z axis LLSS (as I have these to hand). I've also attached a summary table for the pre/post results in the other axes.
IRstuff (Aerospace)
1 Jun 12 11:38
The server does not like the ampersand in your file name
TTFN
Close Box
Join Eng-Tips® Today!
Join Us             Close
