Does anybobody have (or a link to)
Does anybobody have (or a link to) the transient solution to the heatup of a hot water tank?
For simplicity, assume the system adiabatic with the tank water stagnant and it's initial temperature T1.
The heat exchanger area is A and the overall conductance is U. The heat source is hot water coming from the boiler at a constant temperature T0.
I need the time history of the tank water temperature,T
I found this equation:
UA/wc=ln[1-Mc/wct*ln{(T0-T1)/(T0-T)}]
But I need proof.
Anybody??
Thank you for your help.
M weight of water in tank
c specific heat
w flow rate
T1 initial tank water temperature
T0 incoming boiler temperature(constant)
t time
RE: Does anybobody have (or a link to)
I am working on just such a program. The equation you found does not account for ambient air temp or heat loss from convection and radiation. Mine does.
Provide the tank diameter, height (assuming a vertical type cylindrical tank), wall thickness, insulation type, insulation thickness, type of outside surface, ambient air temp. and heat input please.
Look in Kern's Process Heat Transfer. It is derived there.
Good luck,
Latexman
Latexman: That is where I got the equations for convective heat transfer hc formulas.
In your OP, w is a flow rate so the water is not "stagnant."
As noted by Latexman it is the same equation (after rearranging a bit) as eq.18.9 , page 627, of Kern. I think however that a minus sign should precede the external logarithm.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
Kern references Bowman, R. A., A. C. Mueller, and W. M. Nagle, Trans. ASME, 62, 283-294 (1940) for the documented derivation if that's easier for you to fine.
Good luck,
Latexman
Latexman,
Thanks for the references, but cannot get either.
So I guess I'll derive it myself when I get time.
The derivation can be found on the web with some persistant searching.
Good luck,
Latexman
I was easier to derive it.
