AWS D1.1 Minimum double fillet
Hi and thanks in advance
i have a problem with double fillet welding joint for a built up 3 plate beam, theres a concern for the web of the beam , because is a 3/16" plate
is it possible to make the double fillet conection for a 3/16" web to 3/8" and 1/2" flange
i was reading AWS D1.1 but im not sure
RE: AWS D1.1 Minimum double fillet
With low hydrogen electrode, the minimum fillet weld is based on the thickness of the thinner part. For 3/16 material the minimum fillet is 1/8.
www.FerrellEngineering.com
if this is so ... i cant use web plate thinner than 0.28" in A-50 steel
is this right?
THX
