Using Ferrules
Using Ferrules
Hi
can ayone advise on the use of ferrules when terminating,
Apparently in EN60204 is mentions about the means of retaining conductor strands,
so if we were terminating to a contactor say, would you use a ferrule to conform to EN60204 ?
thanks
thanks
RE: Using Ferrules
RE: Using Ferrules
My point is that some contactor terminals themselves may satisfy the requirement and if you use ferrules, the standard terminals on the contactor may not be designed for them. You really need to check on a case by case basis. Every contactor mfr I know of will provide you with the required data.
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
