user defined feature
i found how the UDF works, but the thing i actually want is when i try to insert a UDF (like a keyway in an axle), i can modify the expressions myself. whay i really want/need is that when i select an axle the expressions will change themselves based on the value of the diameter. so i sort of need the same pop up as when i try to import the mother part of family members but then with an UDF. how is this made? is there a way to put an excel file on the UDF?
Best regards,
Chevy
NX6, just got 7.5
Win7, 64 Bit
RE: user defined feature
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Sorry
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
but you understand what i want right?
and if the automatic configuration doesnt work or is impossible, the way i mentioned after that is also good, that when i select a diameter of 20. it will search for every value that matches with that diameter of 20
Best regards,
Chevy
NX6, just got 7.5
Win7, 64 Bit
