Hello, I'm trying to solve a pro
I'm trying to solve a problem of two clips, one static and the other moving.
I want to calculate how high/low each clips bends up/down.
the set is in here:
http://files.engineering.com/getfile.aspx?folder=da46387f-82dc-47da-89ac-4b56840ae257&file=Sans_titre.png
How can I make the contact of the part supposed to bend possible and thus solve the set.
I tried to use the surface contact, but never worked kept on receiving errors messages.
Thank you :)
the set is in here:
Thank you :)
RE: Hello, I'm trying to solve a pro
