ASME U1 Manufacturers Data sheet
Hello all
I need to find out how to request or obtain any U1 forms filed out for the pressure vessels in our plant.
Would the manufacturer have these?
Does ASME have copies of these and if so how can I get copies?
thanks
Tom
RE: ASME U1 Manufacturers Data sheet
The manufacturer should have copies of the U-1 forms since they would have supplied them originally. How old are the vessels?
Where are you located? Would they have been filed with any government regulatory agencies?
I'm pretty sure ASME does not have copies.
Look for a National Board number on the data plate if you are US or CRN number if you are in CANADA. These two organizations also keep records.
Thanks Guys
The vessels are any where from 15 to 25 years old.
They are in the US.
can any one request copies from the National Board or do you need to be a member of some organization?
Tom
henegg,
Anyone can request the files from the National Board (www.nationalboard.org) but there is a fee associated with it. You can also expedite the order, if you so require.
everyone. I appreciate it.
Tom
