Is ACI 350 applicable to tanks with liquid grease?
The ACI 350-06 Code (for Environmental Structures) is intended to provide a code that creates concrete structures that contain liquids. This is accomplished by specifying a bit different reinforcement requirements that help keep cracks tight, etc.
I can see this code used for water and waste water type facilities. But if you were designing a tank to hold liquid grease, is there still a need to use 350 (vs. 318)?
The grease is probably about as viscous as water, but with the grease in the material, it seems like the cracks might be self-sealing or something and that rusting of reinforcement wouldn't be an issue with the grease materials.
Thoughts?
Thanks.
RE: Is ACI 350 applicable to tanks with liquid grease?
Anytime you're providing containers for something nasty, you should design to as rigorous of a code as practical. ACI 350 has some provisions regarding load factors and crack control which are a pretty good idea anyway. While most cracks will self heal, no owner wants to depend on that.
If you're questioned by superiors or a building official on what kind of design you did to keep a load of grease from washing into the crick, it's nice to say you used the special code for Environmental Structures.
Well, with the grease, I would think the cracks would be less self healing because you won't get the formation of calcium silicate hydrate (I think that's right) that typically plugs up hairline cracks. Conversly, I think the fat molecules are probably larger than water molecules, so they may leak less than water with equivalent size cracks. Dunno.
Personally, I would still use 350.
Did you ask ACI? If you do and they respond, please post the answer here.
It is commonly assumed that carbon steel won't corrode in contact with petroleum products. If the grease in question is a waste food-product grease, that wouldn't necessarily be the case, though.
