Ever seen this?
Ever seen this?
Ever seen this?
You can see the sketch path, yet the sweep is 180° off. Not an ideal way to start my day.
Jeff Mirisola
Director of Engineering
M9 Defense
My Blog
RE: Ever seen this?
Link not working.
RE: Ever seen this?
Very interesting!
That's not a bug ... it's new feature which creates a mirrored version before the original. smile
Can you post the part to play with?
RE: Ever seen this?
What are the settings on the sweep?
Dan
www.eltronresearch.com
Dan's Blog
RE: Ever seen this?
Dan,
They're the usual settings: follow path, etc. If I create the same profile on the opposite side and create the sweep using the same path, it works just fine. However, I ended up having to change gears anyway and went with some surfacing instead.
Jeff Mirisola
M9 Defense
My Blog
RE: Ever seen this?
Jeff maybe it might be related to the bug they fixed with sketches on the top plane having the wrong default orientation. The problem does look like a bit of a doozey.
Good thing there are a great many ways to do anything with SolidWorks. I also know that you know SolidWorks inside and out. Maybe you also need to learn it upside down.
CorBlimeyLimey thanks for the That's not a bug... it's a new feature post I'm still chuckling a little bit.
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
