CodeCalc 2011
CodeCalc 2011
CodeCalc 2011
Does anyone know why CodeCalc assumes that if a material (SA-266 GR4) is normalized that it is also fine grained? The progam, when "Normalized" is checked does not allow you to change the curve used for UCS-66, It assumes that you have a fine grained material and defaults to Curve C. I don't believe this is always the case.
