Boundary Lubricating in Low-Pressure Application
I'm trying to find theoretical documentation or insight relating to boundary lubrication in a low-pressure application. I'm trying to model the static friction in a system consisting of metal-to-metal contact, wetted by a (somewhat viscous) fluid (sorry I can't disclose the specifics).
The relative speeds of the two metals are not high enough to generate full lubrication.
Thanks!
(First post, I hope to be able to contribute soon!)
Thanks!
RE: Boundary Lubricating in Low-Pressure Application
Good website on all things tribological:
http://www.tribology-abc.com/default.htm
Google Books can be an amazing tool for quick searches on specific technical topics:
http://www.google.com/search?q=boundary+lubrication&tbm=bks&tbo=1#q=boundary+lubrication&hl=en&tbo=1&tbm=bks&ei=KiXGT_KBMIPo9AS9o5m5Bg&start=10&sa=N&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&fp=dda2d38c14d9c2b3&biw=1238&bih=569
What I guess I'm really searching for is a theoretical explanation as to what makes a wet surface slippery. I don't know if boundary lubrication is the proper term describing this regime of friction.
You've left open the question of what constitutes "low pressure." 200 bar? 10 bar?
I'm probably going to end up conducting a test isolating the static coefficient of friction of the contacting surfaces, it's just that I don't know what fundamentally causes wet surfaces to exhibit a lower static coefficient than dry ones, since there is no relative movement in the static scenario (or is there?).
Thanks for the help.
Mike Halloran
Pembroke Pines, FL, USA
