Condensate Trap
Condensate Trap
I am designing a small 3" Gas control system. The media is wet biogas and the customer has requested a condensate trap situated before the main isolation valve.
Whenever we deal with biogas, we usually use a special filter (after the isolation valve) which includes a sump with a drain tap. However they have asked for a trap upstream of this. My question is; Does anyone know of a specific component that I can use or will an american style sediment trap (T piece configuration) with a tap of some sort be sufficient? I'm in the UK so we don't use a sediment trap as standard as some other countries do. There are plenty of high spec sediment and condensate traps on the market, but they are all a bit overkill for our requirements. They are usually situated directly after the biogas digester and therefore need to be much sturdier (and more expensive) than I require.
I know the question is quite vague, but that's all i've got to work with at the moment. Any advice would be appreciated.
RE: Condensate Trap
What would you be doing, if you knew that you could not fail? Ans. Bonds and derivative brokering.
RE: Condensate Trap
