Metering Readout Problem
Hi to all,
I would just like to ask your inputs with regards to the metering readings in the attachtment.
What problem does this reading pose?
What are the possible causes?
Any input is well appreaciated.
Thanks!
Thanks!
RE: Metering Readout Problem
It will be causing power to be recorded incorrectly.
Good on ya,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
Thanks for the favor, well appreciated.
To all who replyed, thank you.
We'll be checking connections by the earliest possible time - plant in operation right now.
smallgreek,
Application is protection relaying w/ SEL 351 sir.
sir, as per setting, 67 elements are disabled. i will verify this setting with designer asap.
Thank you.
smallgreek,
thank you for pointing that out sir, i will also confer this to the designer.
Lots of thanks!
