Beam supporting motor...
My client is looking to install some motors on top of some existing steel beams to lift a platform for plays. There are two 15"-42# I beams spaced 16" apart. There are three sets of beams like this with 2x12's @ 24" o.c. spanning from one set of beams to another. There are also 1-1/8" x 4" slats on top of the 2x12's. I plan on determining the max weight the beams can handle but before I start doing the calcs do you think I have to take any kind of vibration or anything else into account? Thanks.
RE: Beam supporting motor...
I worry a lot about vibrations working loose any connections. Address this.
