Loading continuous beam with 2 unequal spans
Apologies if I'm asking such a stupid question but can anyone here tell me the formula to calculate the loading on 3 supports of a beam when there is unequal spacing between them and the beam has a single offset point load?
The point load is 1020kg offset 950mm from the left.
Support 1 is at the edge of the beam with support 2 offset 1760mm and support 3 offset (1760+1100mm)
RE: Loading continuous beam with 2 unequal spans
This is solveable by hand in five minutes usin6 statics, FEM's, and moment distribution - 2 minutes with Beam pro.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
Look at this link using the three moment equation
http://www.roymech.co.uk/Useful_Tables/Beams/Continuous_Beams.html
Sorry for the late reply, but thanks for all the help guys. Its much appreciated.
