ISO: 120vac Sliding linear contacts
3
Hi there!
Today I've been trying to hunt down some sliding linear contacts. I'd like to find a retail example of some pretty straightforward designs capable of operating on standard US line voltage. So far I've been surprised with my lack of options and I wonder if it might be due to a fundamental inadequacy of contacts used in this way. I have seen some similar barbed "taps" used for landscaping which pierce the insulation, but I wonder if a sliding arrangement exists.
Thanks for any info!
-kevin
RE: ISO: 120vac Sliding linear contacts
are you talking about contact/bus bar arrangements like used in some track lighting?
Yes- although I'm really talking about whatever I can get. Ideally, it WOULD be a sliding contact on a flexible cord, but given that would probably never pass UL or support a 120vac rating, we're willing to make a lot of compromise.
The track lighting examples I've seen have been for DC powered lights except for the half-turn socket type installations. Also, those have been 2 conductor rails, and I would guess we would want to have a grounded solution.
must it be sliding or do you simply want something you can install anywhere along a cord (one time installation).. the later being simple..
Well, that's one of those compromises. I'd love to find sliding if it existed, but in lieu of that, I would probably settle for a re-positionable something (I don't think we could compromise all the way to a "one time" only install).
120V track systems are readily available..
As you said I HIGHLY doubt an insulation piercing "re-positionable" connector exists as I'd expect UL to poo poo it in a second (and they should)
Good luck.. Time for compromise.
Sounds like you are dead set on a cord solution versus a track.. If so I'd be looking at having multiple/various length pluggable wire links. Like rope lighting I guess where the customer could cut/install the plugs themselves. Or build the insulation piercing into the actual fixture.. Cut a length of lamp cord and snap it into the fixture and you are done.. Ever need to move it simply rip it out of the fixture and cut a new lamp cord section.
Well, I'm not dead set, but I'm doing my best to keep to end up with a satisfied client. If it was easy I wouldn't have ended up here! [smile] Anyway, thanks for the replies! If any other ideas pop up, I'm all ears! [bigears]
Thanks!
I have used what is commonly known in South Africa as Figure 8
220V Power Cable for temporary lighting & Xmas tree light strings, & has a system of lampholders with pointed contacts that pierce thru the insulation & into the 2.5mm stranded conductors.
It meets the South African Codes of Practice.
thanks gattie- can you either link me to an example or give me a good buzzword to google? the term "figure 8" is primarily coming up with those specific 8-shaped connectors. I don't see any examples of the piercing of insulation associated.
What if you redefine your need (a little)?
Could you use a flexible channel cable tray/trough similar to what's used in elevators and computer printer heads (sort of)?
I'm picturing a fixed-length cable in a segmented, flexible carrier that moves along a linear range of positions.
http://www.conductix.us/products/conductor-bar-systems/insul-8-8-bar-conductor-bar/
Mike Halloran
Pembroke Pines, FL, USA
Chiprme: I like that idea a LOT, and I have a cad model concept that sort of illustrates it. The biggest hurdle I have with that one is that I will actually need multiple sliding conductors, and therefore multiple flexible (overlapping?) bands, so it does get a little tricky there, but its a great suggestion.
Mike: That is the 1st time I've encountered something like that, and its also a great suggestion. I'm going to read up on that in more detail and include the example in my presentation, thanks!
Salukikev
Google Winkle Industries - Crane Downshop leads.
Regarding my other suggestion I will attempt to get the trade name of 'figure 8' system
Gattie: Thanks! I appreciate it! The winkle suggestion is essentially the same idea as Mike's link. It's probably about 500x out of scale for what I had in mind, but conceptually I like it.
How about a fixed length flexible cord with a spring loaded take-up reel to keep the cord from piling up?
The fixture could slide along a track for purely mechanical purposes. The cord could pay out from the reel inside the fixture into the track (for protection and concealment).
That's an interesting one. Probably mechanically expensive, but I really like it because although I was originally imagining it as a rigid track, I guess it could also be traditional cord reels, more or less, and in that way remain flexible. I have a feeling this will definitely be cost prohibitive (& probably bulky), but I'm going to render it anyway- thanks!
-k
Conductix also sells festooning systems.
Mike Halloran
