can you delete a solid body or surface
I am wondering if there is a way to delete a body that I have used to define a feature. like if you want to split something with a surface for example. Usually it is moved to a different layer or hidden. The problem is if somebody uses the model and doesn't know what geometry to use. I am also using nx5, but might use nx8 in the future.
RE: can you delete a solid body or surface
Quote (aluminum2)
Only if you are willing to lose the defining parameters of the feature.
Quote (aluminum2)
NX provides ways to determine the parents and/or children of a given piece of geometry. Other users will be able to figure out what you have done and how you have done it.
www.nxjournaling.com
In NX 8.5 we will be providing a new function, 'Delete Body', which will delete either Solid or Sheet bodies WITHOUT destroying the parametric nature of your part model, even if a deleted body had been used as a 'tool body' in some previous Modeling operation.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thats what I was hoping for, just too bad its 3.5 versions ahead of us. Siemens really made a lot of good improvements to UG in that time.
it's actually 5 releases past the one you've got: NX6, NX7, NX7.5, NX8 then NX8.5 bigsmile
Anthony Galante
Technical Resource Coordinator
NX4.0.4MP10, NX5.0.6, NX6.0.5, NX7.0.1, NX7.5.0-> NX7.5.5 & NX8.0.0 -> NX8.0.1
