Identifying a Warren truss
I am doing a routine inspection of about a dozen identical roofs built in the 40's and 50's. They each have three of these trusses constructed with 3x timbers and shear plates (42' span, 15'oc).
At this point I am just trying to identify the type of truss. Since it has no vertical webs it looks something like a Warren truss with extra diagonals.
Thanks in advance.
Thanks in advance.
RE: Identifying a Warren truss
Or the 1830's Town Lattice truss see
http://en.wikipedia.org/wiki/Lattice_truss
In my 1960 Data Book for Civil Engineers it is called a lattice truss. No design information is given.
You would have to run some calculations to determine if the design requires just tension or just compression or both tension and compression for the web design.
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
The Brown truss looks right. That would explain the bolt through the web intersections if they were expected to be in compression (based on the wiki).
Also it might resolve another matter that came up. At one location the edge of the shear plate was visible below the top cord where the webs tied in. It occurs at the first panel point from the end. The drawing also shows a small edge distance there but it shouldn't be critical if the web turns out to be in compression.
Michael.
Timing has a lot to do with the outcome of a rain dance.
