Sheet metal rolling issue
Hi I'm trying to make a half cylinder in sheet metal. I revolved the retangular section to create the shape. After this I used the "convert to sheet metal" command to change the part to sheet metal. The problem is when I create a blank the blank is smaller than the part and also any circular cutouts in the blank can not be dimensioned. Any idea What I'm doing wrong? Sample part is included.
RE: Sheet metal rolling issue
http://www.eng-tips.com/viewthread.cfm?qid=290188
http://www.eng-tips.com/viewthread.cfm?qid=318888
HTH,
Ryan
Ryan Gudorf
CAD/CAM Supervisor
Budde Sheet Metal Works, Inc.
305 Leo St.
Dayton, Ohio, U.S.A. 45404
Tel: 937.224.0868
Fax: 937.224.1356
http://www.buddesheetmetal.com
