Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I'm so glad I found this site... Now I can get some sleep, because my problem is solved..."
Geography
fabiogardenghi (Mechanical)
28 May 12 16:15
Is it possivel in the SAP2000 to fix a limit of displacement in a restraint?
For example:
I have a restraint that is defined: Translation 2 and 3 = Fixed / Translation 1 = Free.
But I want to limit the displacement in direction 1 in 20mm, because I have a mechanical stop.
Any one can help me?
Thanks.
Nonlinearer (Structural)
29 May 12 8:40
Use a spring initially and iterate the analysis until you get 20mm translation.
IR
stressed (Civil/Environmental)
21 Jun 12 12:25
Define a nonlinear link Gap or Hook, depending on whether it's compression or tension, with 20mm opening and run load case as a nonlinear analysis. Local direction of Link needs to correspond with joint local axis 1 (X) in your example. This problem requires a nonlinear analysis
Close Box
Join Eng-Tips® Today!
Join Us             Close
