NX7.5 TC - moving 2D data from one sheet to another
I'm wanting to export 2D data from one NX .prt file to another using the following path : -
File > Export > Part Specification (select 'existing').
The objects are selected and then exported - but to, what was, a non-existing sheet 2 of 2. Why is the selected data not imported into an existing sheet 1 of 1? And how can I get the data, as copy and paste does not function in NX7.5 TC, to sheet 1?
RE: NX7.5 TC - moving 2D data from one sheet to another
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I've tried, without success, to copy/cut and paste from sheet 2 to 1 - and oddly enough this malfunction occurs in both native and Tc NX. The response dialog on the failed attempt reads "None of the objects selected are supported for Copy" (screenshot of response dialog is attached).
Unless there's a customer default not set correctly then I'm at a bit of a loss.
The help is really appreciated.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
jerry1423 - many thanks for the 'associated to view' thought and the malfunction only occurs with note if associated to view. As I was initially trying to export curves and notes I had assumed that the issue involved all entities - this is not the case. The exported data still imports into the desired existing NX file and to a new drawing sheet but this, now, is just a minor issue.
Many thanks once again guys.
