Hi everyone,
I am using specgram to generate spectrum in time domain for visual analysis on audio signals. It will have good and clear visual effects while using NWINDOWS (128 PTS FROM HANNING), NOVERLAP = 100PTS UNDER 512 PTS FFT.
Questions to me as I want to implement the same overlap with windowing in my c source code:
I don't understand how the overlap works in specgram.m below.
Especially, these lines: (e.g., nwind = 129,ncol=6570)
y = zeros(nwind,ncol);
% put x into columns of y with the proper offset % should be able to do this with fancy indexing! y(:) = x(rowindex(:,ones(1,ncol))+colindex(ones(nwind,1),:)-1);
% Apply the window to the array of offset signal segments. y = window(:,ones(1,ncol)).*y;
Thanks a lot for anyone's prompt reply. Greatly appreciated.
********* specgram.m from Matlab 6.5 ********** function [yo,fo,to] = specgram(varargin) %SPECGRAM Calculate spectrogram from signal. % B = SPECGRAM(A,NFFT,Fs,WINDOW,NOVERLAP) calculates the spectrogram for % the signal in vector A. SPECGRAM splits the signal into overlapping % segments, windows each with the WINDOW vector and forms the columns of % B with their zero-padded, length NFFT discrete Fourier transforms. Thus % each column of B contains an estimate of the short-term, time-localized % frequency content of the signal A. Time increases linearly across the % columns of B, from left to right. Frequency increases linearly down % the rows, starting at 0. If A is a length NX complex signal, B is a % complex matrix with NFFT rows and % k = fix((NX-NOVERLAP)/(length(WINDOW)-NOVERLAP)) % columns. If A is real, B still has k columns but the higher frequency % components are truncated (because they are redundant); in that case, % SPECGRAM returns B with NFFT/2+1 rows for NFFT even and (NFFT+1)/2 rows % for NFFT odd. If you specify a scalar for WINDOW, SPECGRAM uses a % Hanning window of that length. WINDOW must have length smaller than % or equal to NFFT and greater than NOVERLAP. NOVERLAP is the number of % samples the sections of A overlap. Fs is the sampling frequency % which does not effect the spectrogram but is used for scaling plots. % % [B,F,T] = SPECGRAM(A,NFFT,Fs,WINDOW,NOVERLAP) returns a column of % frequencies F and one of times T at which the spectrogram is computed. % F has length equal to the number of rows of B, T has length k. If you % leave Fs unspecified, SPECGRAM assumes a default of 2 Hz. % % B = SPECGRAM(A) produces the spectrogram of the signal A using default % settings; the defaults are NFFT = minimum of 256 and the length of A, a % Hanning window of length NFFT, and NOVERLAP = length(WINDOW)/2. You % can tell SPECGRAM to use the default for any parameter by leaving it % off or using [] for that parameter, e.g. SPECGRAM(A,[],1000) % % SPECGRAM with no output arguments plots the absolute value of the % spectrogram in the current figure, using IMAGESC(T,F,20*log10(ABS(B))), % AXIS XY, COLORMAP(JET) so the low frequency content of the first % portion of the signal is displayed in the lower left corner of the axes. % % SPECGRAM(A,F,Fs,WINDOW) where F is a vector of frequencies in Hz % (with 2 or more elements) computes the spectrogram at those frequencies % using either the chirp z-transform for more than 20 evenly spaced % frequencies or a polyphase decimation filterbank. % % See also PWELCH, CSD, COHERE and TFE.
% Author(s): L. Shure, 1-1-91 % T. Krauss, 4-2-93, updated % Copyright 1988-2002 The MathWorks, Inc. % $Revision: 1.8 $ $Date: 2002/03/28 17:30:53 $
error(nargchk(1,5,nargin)) [msg,x,nfft,Fs,window,noverlap]=specgramchk(varargin); error(msg) nx = length(x); nwind = length(window); if nx < nwind % zero-pad x if it has length less than the window length x(nwind)=0; nx=nwind; end x = x(:); % make a column vector for ease later window = window(:); % be consistent with data set
ncol = fix((nx-noverlap)/(nwind-noverlap)); colindex = 1 + (0:(ncol-1))*(nwind-noverlap); rowindex = (1:nwind)'; if length(x)<(nwind+colindex(ncol)-1) x(nwind+colindex(ncol)-1) = 0; % zero-pad x end
if length(nfft)>1 df = diff(nfft); evenly_spaced = all(abs(df-df(1))/Fs<1e-12); % evenly spaced flag (boolean) use_chirp = evenly_spaced & (length(nfft)>20); else evenly_spaced = 1; use_chirp = 0; end
if (length(nfft)==1) | use_chirp y = zeros(nwind,ncol);
if ~use_chirp % USE FFT % now fft y which does the columns y = fft(y,nfft); if ~any(any(imag(x))) % x purely real if rem(nfft,2), % nfft odd select = [1:(nfft+1)/2]; else select = [1:nfft/2+1]; end y = y(select,:); else select = 1:nfft; end f = (select - 1)'*Fs/nfft; else % USE CHIRP Z TRANSFORM f = nfft(:); f1 = f(1); f2 = f(end); m = length(f); w = exp(-j*2*pi*(f2-f1)/(m*Fs)); a = exp(j*2*pi*f1/Fs); y = czt(y,m,w,a); end else % evaluate DFT on given set of frequencies f = nfft(:); q = nwind - noverlap; extras = floor(nwind/q); x = [zeros(q-rem(nwind,q)+1,1); x]; % create windowed DTFT matrix (filter bank) D = window(:,ones(1,length(f))).*exp((-j*2*pi/Fs*((nwind-1):-1:0)).'*f'); y = upfirdn(x,D,1,q).'; y(:,[1:extras+1 end-extras+1:end]) = []; end
t = (colindex-1)'/Fs;
% take abs, and use image to display results if nargout == 0 newplot; if length(t)==1 imagesc([0 1/f(2)],f,20*log10(abs(y)+eps));axis xy; colormap(jet) else imagesc(t,f,20*log10(abs(y)+eps));axis xy; colormap(jet) end xlabel('Time') ylabel('Frequency') elseif nargout == 1, yo = y; elseif nargout == 2, yo = y; fo = f; elseif nargout == 3, yo = y; fo = f; to = t; end
function [msg,x,nfft,Fs,window,noverlap] = specgramchk(P) %SPECGRAMCHK Helper function for SPECGRAM. % SPECGRAMCHK(P) takes the cell array P and uses each cell as % an input argument. Assumes P has between 1 and 5 elements.
msg = [];
x = P{1}; if (length(P) > 1) & ~isempty(P{2}) nfft = P{2}; else nfft = min(length(x),256); end if (length(P) > 2) & ~isempty(P{3}) Fs = P{3}; else Fs = 2; end if length(P) > 3 & ~isempty(P{4}) window = P{4}; else if length(nfft) == 1 window = hanning(nfft); else msg = 'You must specify a window function.'; end end if length(window) == 1, window = hanning(window); end if (length(P) > 4) & ~isempty(P{5}) noverlap = P{5}; else noverlap = ceil(length(window)/2); end
% NOW do error checking if (length(nfft)==1) & (nfft<length(window)), msg = 'Requires window''s length to be no greater than the FFT length.'; end if (noverlap >= length(window)), msg = 'Requires NOVERLAP to be strictly less than the window length.'; end if (length(nfft)==1) & (nfft ~= abs(round(nfft))) msg = 'Requires positive integer values for NFFT.'; end if (noverlap ~= abs(round(noverlap))), msg = 'Requires positive integer value for NOVERLAP.'; end if min(size(x))~=1, msg = 'Requires vector (either row or column) input.'; end
