Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have learned more through this forum than I did on a two day course. Thanks to everyone for their help and other postings that I have found useful..."
Geography
CabreraR (Civil/Environmental)
27 May 12 0:59
I am working as cost engineer and something came to my table that really seems more a joke than a serious work. I received a man-hour estimate for a scope of work for producing a FEMA type flood map for 640 acres, the global stability analysis for 2.5 miles of levee, dam breach analysis, levee overtopping and many other assumptions showing about $64K.
I developed an estimate for $421K. Other has estimate that the study will be between $300 and $500K. Is anyone out there that can pitch a bull-pack number in term of cost and duration?
Rye1 (Civil/Environmental)
27 May 12 22:29
Where is the study located? This has an impact on cost. I really think there is more to this than you are asking. The 640 acres is 1 sq mi and is often the FEMA minimum limit for floodplain mapping. FEMA floodplain mapping is often estimated in stream miles beginning at the 1 sq mi drainage area. Just from reading you basic question, I would think that an estimate closer to $64K may not be out of the ball park. I would think $500k would be out there, if I'm understanding your question correctly.
Robert Billings
www.newrivereng.com
cvg (Civil/Environmental)
28 May 12 10:22
the dam break study alone could be $50k
depending on the need for geotech investigation, the levee stability analysis could be $25k - $50k or a lot more
add another $50k - $100k for FEMA floodplain delineation
I'm thinking you need to define the scope and schedule a bit better on this one
cht13er (Civil/Environmental)
28 May 12 15:50
Why is the study area so small - are you in a city?
28 May 12 23:13
Thank you for your inputs.
The study will be conducted by a US firm in a city in Mexico right in the US border where, to begining with, no topographical data in electronic format exist. I got from another source that just the geo study for 2 miles of levee is about 100K which match the estimation using USACE criteria, sampling every 1000FT top and bottom of levee.
Believe or not, I have same questions yuo are have due to the SOW that is open for a consultant to came with anything they want.
At least, I am sure that I am not wrong thinking that the SOW as writen, is a recipe for a trouble.
thank you all
Close Box
Join Eng-Tips® Today!
Join Us             Close
