HS-98 overtravel problem
I randomly getting 501 overtravel -Z alarm. Can't figure out the cause.
RE: HS-98 overtravel problem
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
What has happened is the head has crashed at some point, and the coupling between the servo and the screw has slipped. It is designed to do this. Because it slipped, the position of the z axis has shifted up just a bit.
MDI mode
Offset setting (Hard Key)
Setting (Soft key)
It should say "parameter write 1:enable 0: disable
Type the number "1" INPUT
System (Hard Key)
PARAM (Soft key)
type in the number 1850 "NO.SRH" (soft key)
Write done everything on that page.
High light just the value for Z type the number you want then hit "INPUT".
"0" INPUT then hit RESET to clear the alarm.
If you want to move it 0.020" (inches) then
20X25=500.
take the original value and add or subtract 500 depending on which way you want to go.
HS-98 suppose to work with minimum 20 gage materials. But I'm cutting 24 gage.Thats a problem.
