Amada Laser FO-3015 NT - Unable to find the root cause
Hi, my client has a Amada laser FO-3015NT with Fanuc controller cutting precision problem. The Amada service team have changed all the parts that they thought might causing the problem but failed to rectify it. Anyone can help or had the similar problem?
thanks
thanks
RE: Amada Laser FO-3015 NT - Unable to find the root cause
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
If there is a language problem, I can understand the difficulty. But, the least you can do is answer the questions asked when someone is trying to help you.
