Dimpling rivets bad for pressurised aircraft?
I've heard dimpling aircraft skin is bad practice in pressurised aircraft.
(A) Can someone confirm this?
(B) Direct me to a proper reference?
RE: Dimpling rivets bad for pressurised aircraft?
b) i'd consult bruhn or niu
a choice might be intrenal doubler with knife-edge rivets ... it's not good practice but that doesn't mean you can't ... maybe look into the fatigue aspect (i figure you're a GA a/c or Pt23).
SRM for aircraft says to only use LZ (NAS1097AD) -4 rivets in 0.040" or more skin if in a prssurised area.
Am I able to go knife edge as you've suggested if I can show OEM has done it and also fatigue aspect is fine?
Appreciate your thoughts.
observation ... 0.04" skins are pretty heavy for an unpressurised plane.
