Weld 14 ga metal
Weld 14 ga metal
What would be the correct way to weld a 14 ga metal hanger (galvanized) to a 1/4" steel (Fy=36ksi) plate?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Weld 14 ga metal
If you insist on welding, grind off the zinc first, or suffer metal fume poisoning.
Mike Halloran
Pembroke Pines, FL, USA
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
The welders must be certified to both code provisions. D1.3 is sometimes more difficult to certify than D1.1.
Depending on the configuration of the connection, the certification must be for either fillet conditions or plug conditions. In qualification on sheet steel, they are similar.
