chiller water system make up water treatment
what is normal practice on the treatment of make up water for hydronic system
is a Y strainer suffeciant or is a finer filter required?
RE: chiller water system make up water treatment
Strainer you need anyhow, at your circulation, regardless of make-up arrangements. Depending on armatures it is possible that you will need multiple strainers to protect sensible valves.
