Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This site is like first coffee in the winter morning..."
Geography
SceneryDriver (Electrical)
25 May 12 12:14
Hi All,
I seem to remember, several versions and years ago, that AutoCAD had an option under Array where you could pick the distance over which the array would be placed, as well as the familiar number of columns, rows, etc...
For instance, say I had a line, A, 67 inches long, and I had another line, B, perpendicular to it. If I wanted an array of 19 lines "B" over that distance of 67 inches, it works out to 3.52-ish inches. I had to do the division manually; is there a way to have AutoCAD do that for me in the current (2011) version?
Am I remembering incorrectly, or has that functionality simply been "placed" somewhere else over the years (I don't even remember seeing that option disappear from the Array dialog box in a new version)? I've never known AutoDesk to remove functionality; maybe they just called it something else.
SceneryDriver
rollupswx (Mechanical)
25 May 12 18:03
You could create a polyline or spline and use the Divide or Measure command with Block option to get what you want.
I think with 2012 and later you can do this with the array command directly.
IFRs (Petroleum)
25 May 12 21:16
The key word in rollupswx post is MEASURE
Helpful Member!  chicopee (Mechanical)
2 Jun 12 13:26
you can use the POINT command to divide the A line into 67 segment and do a DI, with not less than 6 significant numbers after the decimal point, between two points. This value can be used in the column offset of your ARRAY command.
2 Jun 12 22:21
Thanks, chicopee! That's exactly what I was looking for!
-ScenereyDriver
Close Box
Join Eng-Tips® Today!
Join Us             Close
