Hec Ras X Section Scale
Does anyone else have a problem with importing the DXF cross sections from Hec Ras into Autocad? I exported the sections to DXF all at once (using the multiple option), but when they're all at bizarre scales... lFor example, on one section stations 0+00 to 1+60 instead of scaling 160 feet, scales 120 feet. then the next X section will scale 100 and another will be 160... also the y scales are all over the place as well, making it so that i cannot even alter these sections into a usable Scale
RE: Hec Ras X Section Scale
