padmount dist xfmrs & lightning
We know the cause was lightning, I just want to understand why...
Single phase underground line with a lightning arrestor and line fuse at the TP pole (terminal pole - where the line goes from OH to UG). The line has 15 or so padmount transformers on it, serving 20 or so customers. All tubs are 120/240V, 15 - 25 kVA. The last tub on the line also has a lightning arrestor; the line ends at this tub. All the transformers have 2 ground rods - one in the basement, driven 7.5' and one 6' in-front of the tub (for step-potential).
We had a bit of a storm... got 4"+ of rain and lots of lightning. We suspect lightning struck the ground (as in the physical Earth) in the vacinity. Of the 15 transformers, 9 had blown bay-o-net fuses. The line fuse did not blow, both arrestors were good. All of the transformers held when re-fused. I assume, the lightning strike to the ground caused a rise in ground potential, question is: how did this result in the transformer bay-o-nets blowing? All tubs are fed in-and-out. De-energizing a single tub (pulling elbow) does not de-energize tubs further down the line. The tubs with blown fuses were not in series... it would skip 1 or 2, hit 3, skip 1, hit 2, etc. It is possible the conductor is bare-concentric (I'm not sure if that contributes).
you can't fix stupid
RE: padmount dist xfmrs & lightning
Hmm. Tub in this context being the handhole upon which the padmount sits? I've not heard this jargon before. For feed-through padmounts, pulling one elbow will de-energize all downstream units. However, if the 'tub' contains a 3 way 'junction box', its is possible to pull the one elbow feeding that unit without affecting downstream transformers.
'tub' is the slang we use for just about any transformer. ;) All our transformers are feed-thru... It's probably just how we spec them.
@jghrist
I like the over-excitation theory in terms of an explanation
