Opening TC NX without opening NX
When I open NX outside of teamcenter, I open the native version which is not connected with TC. Is there a way to open the connected version without having to open teamcenter?
Since TC (or at least the navigator) is implemented inside of NX I often don't see the reason.
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
RE: Opening TC NX without opening NX
Please look at my taskbar, there is only a NX symbol so i don't have a TC session open, but still working in the database of TC.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
I assume you have some help from a sys-admin because it's not that easy.
There is also a complete help forum on this site :
https://bbs.industrysoftware.automation.siemens.com//vbulletin/index.php
Best regards,
Michaël.
24.0 GB
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
It is not that complicated. Below is an example of the batch file that we use.
Obviously you will need to change the path names to match your installation.
Most of our designers never open TC and only use this script.
set TC_ROOT=C:\UGSPLM\Teamcenter\TC83UA
set TC_DATA=\\dellserver3\volumes\TCENG\WMTI_83UA_tcdata
rem set environment variables for UGNX
set UGII_BASE_DIR=C:\UGSPLM\NX 7.5
set UGII_ROOT_DIR=C:\UGSPLM\NX 7.5\UGII\
set FMS_HOME=%TC_ROOT%\fcc
set JAVA_HOME=%TC_ROOT%\portal\jre
call %TC_DATA%\tc_profilevars.bat
cd /d %TEMP%
call "C:\UGSPLM\NX 7.5\UGMANAGER\ugmanager"
Jurgen
You would need to have NX installed on your TC server.
Why would you want to run NX on your TC server?
