NX Programming Options
I have a structural simulation in NX 8.0 and I want to repeat it by changing the applied load angle between 40 to 180 degrees in 1 degree increments, and record the strains at 4 specific node numbers to a text file. I believe this can be done in NX by some kind of programming. I've looked at NX help and it seems that there are too many options (not always a good thing!). What is the best choice here? I do not need to have an interaction with the software while it is working, so no need for any GUI development. Obviously I prefer an easy option that won't force us to buy additional licenses!
RE: NX Programming Options
I decided to do it in NX Open. Anyone knows of any sample code for repeating the same solution and writing the results? It should be a common problem.
