Pneumatic Positioner Bailey AP-53
I am not able to find any information related to this positioner on the web.
Does anybody know something about de Bailey AP-53 positioner or where to obtain some information from?
RE: Pneumatic Positioner Bailey AP-53
Hello ICRH,
Try this: http://support.automation.siemens.com/US/llisapi.dll?func=cslib.csinfo&lang=en&objid=31803544&caller=view
As is indicated this is a replaced model. Common for this kind of diversified instrumentations used as 'additionals' for valve controls is that they are often supplied from actuator suppliers, air equipment suppliers and other 'non manufacturors' of the product. Very often documentation is incomplete, not supplied, or if found - integrated for several models and possible additional equipment and use, and not easily read.
In additional positioners can be very complitated to clean and recalibrate, and in addition new models open for additonal features.
Advice: try to find original supplier and/or buy new. If the unit is failing it might be a simple fault, or on the other end the failure might be in the 'downstream' unit (actuator and/or valve). Consider buying complete new ready calibrated unit together with complete new valve/actuator?
