Emboss a solid part
Emboss a solid part
I'm not able to obtain as the image attached with the emboss command in NX.
Someone can help me ?
Thank you...
Using NX 8 and TC8.3
RE: Emboss a solid part
Frank.
Best regards,
Pascal,
NX5.04+TC2007 (GM Toolkit) / NX7.5 native
The sketch can lie in the face but then the "End Cap" should probably not be "Plane of section".
sorry for the mistake.
I'm looking for as the image attached.
I would like the shape as in sheet metal, but I'm not in sheet metal.
The part is a thermoformed.
Thank you...
It will complain about non uniform thickness but create the dimple.
Or you can extrude the sketch and instead use the Solid Punch , in sheet metal app but does not require "convert to sheet metal".
The "emboss" will not to my knowledge do the "backside" in one operation. It is intended to create complex "embossings". ( see example in the attached part, NX7.5)
Tomas
I can't use your solution because I model a part with shared feature and create a linked body.
So two files create two different mold parts that share the same base shape.
In one I need an emboss for an electronic board and in the other some cut and more.
For Toost,
I used your suggestion, but doesn't knowing the emboss feature, I asked for a simple solution with emboss, but you confirm that emboss is not the solution for this case.
Thank you...
